It is currently Sun Jul 26, 2026 7:22 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Nov 10, 2025 3:00 pm
Thanks for your reply Spence1015.
PostPosted: Mon Nov 10, 2025 3:02 pm
And I didn't even touch on sorting where the pins come from...whew...That depends on what peripheral it came off of, hard drive pin, tele board pin, voltage pin, etcetera.
IMO, the pin category are for companies that have an abundance of gold plated pins that would be used in something they manufacture or produce; and have an amount leftover to sell as e-scrap.
PostPosted: Mon Nov 10, 2025 3:26 pm
Thanks again Spence1015. I now clearly understand the Boardsort escrap price list of Gold Pins at $5 lb. And the blue square meaning Complex Item.
Whew! Is right! Appreciate the reply.
PostPosted: Thu Nov 13, 2025 1:07 pm
Gold pins aren’t intended for consumer scrappers.
I get them repairing broken stuff. You’re not intended to start ripping pins off of otherwise good boards.
PostPosted: Thu Nov 13, 2025 9:08 pm
Thanks. Lostinlodos for your reply. I worked in manufacturing for some years. Had to custom make wire harnesses for various products among other things. I soldered my share of edge connectors. Assembled connectors from bare plastic plug. Inserting pins. Used wave solder. Solder pot. I could go on.
This escrap is new to me. Talk about shifting gears. One needs a metal refiners knowledge at an entry level to start with.
Then you look for a copy of LOSTINLODOS's new book out.
INTELLIGENT E-SCRAPPING.
Problem is. I just can't seem to find a copy.
PostPosted: Thu Nov 13, 2025 9:16 pm
Actually I have a book coming y
Was a partnership with another scrapper who kind of fell out of interest.
I’m waiting for the SOL to expire to publish. Out of respect for his work in helping.
It’s literally everything you don’t want to know about escrap and a general few chapters on standard metals. It literally covers every component you will find in an electrical device.
PostPosted: Thu Nov 13, 2025 9:25 pm
I want the book to literally be the bible of scrap! It’s filled with photos and covers everything—from wet relays of the late 1800s to gates and switches to compound circuits to IC to modern tech
it will be under $10 in ebook format (probably around 50 in hard print)
Estimates on hard copy are 1200 pages.
When— it’s released a coupon code for a free ebook copy will be available to an board sort user with more than 10 posts on Amazon, Kobo, smashwords, Apple and B&N
Currently planning a November 2026 release. If the other author is not against it.
PostPosted: Thu Nov 13, 2025 9:42 pm
Beautiful.
A much needed guide.
I wish you all the success on your project.
PostPosted: Fri Nov 14, 2025 4:44 pm
I think the original discussions about this started roughly a decade ago.
Hopefully the final touches can be done in the coming year.
But every time I feel like I’ve covered all there is to cover realistically— someone else post here some bizarre object that makes me go back and think well now I need to cover this stuff too.
Lol
PostPosted: Thu Nov 27, 2025 6:39 pm
Spence1015 wrote:
Exactly what marked141 said.
I used to pull pins out of anything and everything I sought was worth it or valuable. I wish I never started that. Pins get classed in multiple different areas. Full plating, half plating, spot plating, brass, Cu, unclean or lead/solder left on, etcetera etcetera. It depends on the thickness of plating as well; only determined by analytic radio guns or RF scanners; usually ** paying a little extra each test run to even view the elements and %. Thankfully BS has one.
It goes back to depopulating. If you're already pulling everything off PCBs and boards, go for it; but if not don't even start. Connector ends is far more efficient and better payout.
Some examples of pins that aren't worth the $5.00 lb would be like IDE/ATA pins, the pins you see here that are spot plated at the contact point, or PCIe slot pins, mostly made of manganese brass or a tin; very seldom gold plated on integrated units nowadays.
Wow, I am so glad I read through these comments finally! I have been wondering for quite sometime if it has been worth the tedious time to break apart all of these materials like connectors to get the gold pins. Hearing someone say "I wish I never started" clearly confirms my suspicion. I'm burning valuable time for practically no return. I've always said to myself "If boardsort.com doesn't take them, maybe I'll try to do my own recovery batch for fun".
But let's be real, I got 3 young kids and other responsibilities and way better income generating avenues than spending very tedious hours cutting connectors to fill up a pill bottle with gold plated material. Now if I happen to just easily get some of these, then I'll add it to my collection. But from now on I'm done spending all that time when I could be doing something wrong much more valuable. Thanks guys for all your input!
