It is currently Wed Apr 29, 2026 12:05 am
 Post subject: IC chip ?
PostPosted: Thu Oct 30, 2025 8:30 am
Hello,
Are these actually IC chips? Should I keep them with my other IC chips?
I Googled them and it said they are TAB ICs.
Thank you
RichJ
 Post subject: Re: IC chip ?
PostPosted: Thu Oct 30, 2025 10:47 am
From what I understand, Boardsort does not want these. I leave them attached to the lcd panels.
PostPosted: Tue Nov 04, 2025 9:13 pm
I heard from a FB group that somebody did make the claim that they have gold bond wires in them. However It's not something I personally deal with. I throw away bucket loads of these all the time.
There "might" be something to these but that would be above my knowledge. Not to mention the hazard they pose from the glass...
Abbreviations
HGT - High Grade Telecom
LGT - Low Grade Telecom
HGP - High Grade Peripherial
LGP - Low Grade Peripherial
MGB - Mid-Grade Board
LGB - Low-Grade Board
PostPosted: Thu Nov 06, 2025 1:31 am
These are COF's or sometimes on FFC(IC). COF meaning Chip on Film.
Those ribbons connect the converter board from the Tcon boards to send the info back n fourth. Pixels n what not.
That , die, is an IC chip. You can either leave them on the board or collect them to put in IC. I would assume you have to remove the die from the COF.
PostPosted: Thu Nov 06, 2025 1:33 am
There are no glass attached to these if you remove them from the board carefully. They usually pull up very easily or are stuck with a light glue/sticky tack substance.
PostPosted: Mon Nov 10, 2025 8:53 pm
someone on this forum said to toss into gold end connectors, though no sure. I would email Chris
PostPosted: Tue Nov 11, 2025 8:46 pm
I emailed Chris with a link to this and he hasn't responded... If someone else gets a response please let us know.
PostPosted: Fri Nov 14, 2025 4:42 pm
If there is visible gold it can go as connector end. If not visible, midgrade.
PostPosted: Fri Nov 14, 2025 8:13 pm
There you go folks, straight from Boardsort.
