It is currently Tue Sep 22, 2026 9:37 pm
 Post subject: Cpu and ic id
PostPosted: Wed Nov 19, 2025 1:43 pm
What category would the cpu go under, has gold pins on bottom. IC is ceramic and has silver pins on the adapter board. Should I remove the IC and toss it in with regular IC or does the board adapter put it in another category? Thanks for the help in advance
 Post subject: Re: Cpu and ic id
PostPosted: Wed Nov 19, 2025 2:28 pm
CPU will probably fall into class Foreign Gold cap.
The ceramic IC, does it have a gold cap bottom? Check the bottom ...it is soldered in, correct?
More than likely you'll have to remove it from the board. Tiny cut off nippers or a sharp razor blade; scoring the legs on the board, will remove that chip easily ...but before you do, let's wait for some other opinion's
PostPosted: Wed Nov 19, 2025 2:53 pm
No gold on the IC. Soldered on but easy to remove. Posting Pic of the u decide of cpu as well.
PostPosted: Thu Nov 20, 2025 7:16 pm
Agree with Spence.
PostPosted: Sun Nov 23, 2025 3:34 pm
Welcome. CPUs have multiple classes here.
I just got a bunch of these.
Agree with the assesment re the CPU.
I kept the no gold ceramics on the boards and sent in whole boards as high tele. with no visible gold I figured regular IC and was not sure that that would qualify as IC with that much fiber.
