It is currently Wed Sep 23, 2026 12:18 am
 Post subject: Ic chips
PostPosted: Sat Nov 22, 2025 10:20 pm
Do i have to separate IC chips? Image
 Post subject: Re: Ic chips
PostPosted: Sun Nov 23, 2025 3:36 pm
It looks like you posted a picture. But. It has not uploaded. Briefly. Not all IC's are the same. You got plastic encased. Ceramic encased. Gold cap. Gold leg. They do have value difference. So. Learn and be mindful if what you have to submit to Boardsort. Try again to upload your picture. No one can intelligently comment such a question without an image. Good luck.
PostPosted: Sun Nov 23, 2025 11:04 pm
All what is pictured will go as IC class.
The only time you separate ICs is if they're CPUs, gold pins, gold capped or some ceramic IC that classes higher listed in the forum.
PostPosted: Sun Nov 23, 2025 11:07 pm
Second, The RAM SDRAM ROM pictured in the back; if you have an amount of a half lb or more, you should separate and get a quote from Chris.
