It is currently Mon Aug 03, 2026 10:12 pm
PostPosted: Thu Nov 20, 2025 5:18 pm
Hi,
Not sure what classification this falls under.
High Peripheral most likely but could it go higher?
Thanks.
PostPosted: Thu Nov 20, 2025 7:30 pm
High Telco seems possible, especially if all the connectors have gold pins.
PostPosted: Fri Nov 21, 2025 10:57 am
After reviewing the High Telecom Board escrap video. I personally would submit as High Telecom. You have no junk
as in: shielding ,heat sinks, large capacitors. Has that low profile as mentioned in the video. It is highly populated. Got gold header pins on board. But. As Mark141 mentioned " all connectors have gold pins". Only you at this point can see inside the connectors.Check out the video.
PostPosted: Mon Nov 24, 2025 12:26 am
Looks like high telco. Exactly as catwhisker said the key is high chip density and no junk. Even a few non-gold pins don't ruin the deal in my experience.
PostPosted: Mon Nov 24, 2025 4:36 pm
Telco is not a grade I excel at. I was on the fence without seeing pins so figured if there's gold there on top of everything else it would be safe.
¯\_(ツ)_/¯ I do my best
PostPosted: Tue Nov 25, 2025 1:32 am
Submit High Tel, worst case scenario it gets is Low Tel.
PostPosted: Tue Nov 25, 2025 12:29 pm
Would this ic classify with the rest.
PostPosted: Tue Nov 25, 2025 12:36 pm
Does this IC have any gold legs; I can't really tell?
If no gold legs, IC.
PostPosted: Tue Nov 25, 2025 1:42 pm
No gold legs but u can see gold inside.
PostPosted: Tue Nov 25, 2025 1:44 pm
Any idea what kind of board?
