It is currently Sat Nov 07, 2026 2:58 pm
 Post subject: High grade board?
PostPosted: Tue Nov 25, 2025 1:53 am
Are these high grade boards? And what would they be if i took the ic chips off what grade of board would they be?
 Post subject: Re: High grade board?
PostPosted: Tue Nov 25, 2025 9:37 am
Pull all the batteries! I see one on each of the four top boards but be sure the other two don't have any either.
The three larger boards on the left should be okay. If you're pulling the ICs do remember that could result in a lower grade, but again the three left should be okay.
The right three might clear low Telco or, since there are gold fingers, clean gfc.
