It is currently Mon Aug 03, 2026 6:29 am
 Post subject: Would this go as HP?
PostPosted: Mon Dec 01, 2025 4:02 pm
Hi, would this board go as high Peripheral?
Thanks
 Post subject: Re: Would this go as HP?
PostPosted: Mon Dec 01, 2025 7:22 pm
Assuming that's a fairly thick and heavy board (even with the zinc cast ports on one end). You can pull out that one green term I if you want.
High peripheral would work, this may be leaning into low Telco.
PostPosted: Thu Dec 04, 2025 10:42 pm
High Per.
Pull the laser load sticks. The two metal rectangles. There's two units that pop out like a mini RAM stick. Disassemble those for Low Tel - High Tel.
PostPosted: Fri Dec 05, 2025 11:57 am
Thank you.
