It is currently Mon Aug 03, 2026 4:37 am
PostPosted: Thu Dec 11, 2025 6:57 pm
OSCAR is down, an not knowing that, I took a bunch of pictures. In order to not clutter up the forum, I created an unlisted YouTube Video
Feel free to comment using the number. I understand that the images are front and back with some ends. They may be the same item, but you only need to referance the picture that helped you identify. That will help me learn which side to focus on for my education.
No Sound
Some pics might be RAM but I'm not sure. I just need clarification on those.
If you'd like a better picture, please ask here. Thanks!
Thanks!
https://youtu.be/Dkq_VL5_7ZA
PostPosted: Thu Dec 11, 2025 9:14 pm
That's a lot...
Uhm... I'll try and see if I can offer some grades when I have time unless someone else gets there first.
I would suggest if you do a video again, number the boards instead of the images. So if you have front and back number it 1. Then if the next is just one photo number it 2 and then if you had front, back and a side detail they'd all be 3. Instead of 1,2,3,4,5,6.
PostPosted: Thu Dec 11, 2025 9:36 pm
Yeah, I thought of that, but I was working quick and just numbered the slides since I knew I had 60 pics. I didn't actually look at the image. But I do have another set that I'll try to be more precise.
PostPosted: Fri Dec 12, 2025 8:23 am
I think I'm going to try to at least reupload as a long form. My phone didn't have the option. I'll do it on my computer.
marked141 wrote:
That's a lot...
PostPosted: Fri Dec 12, 2025 5:45 pm
Video comments are off...
4, wifi with fingers
9, cd/DVD board
22, should be good as gold RAM
29, high peripheral
30, low grade hdd board
32, cd/DVD board, pull that little wire out the rest of the way. The black part of the socket will pull out and release the wire.
34, clean gfc
35, backplane
50, backplane
53, gold RAM
57, backplane
60, gold RAM
PostPosted: Fri Dec 12, 2025 7:52 pm
[quote="marked141"]Video comments are off...
Thanks! I fixed it.
