It is currently Mon Aug 03, 2026 10:49 am
 Post subject: Gold finger card or ???
PostPosted: Fri Dec 12, 2025 6:35 pm
Would these fly as clean gfc or do they have too much going on? If not what are you thinking. I also want to thank you guys who take the time to offer your suggestions on all my questions.
PostPosted: Fri Dec 12, 2025 7:11 pm
Older style cards like these can vary. I posted 4 threads back in 2021 with similar style boards and most ended up high peripheral due to components on the board basically being weight without value. Some got Telco and some midgrade.
Are the gold fingers on both sides? The two boards with connectors on the other end have gold pins? Can the through bolts on the transformers be removed easily? The aluminum heatsinks can be pulled.
I think there's room for low Telco to be a possibility depending on the answers to the above. But high peripheral if you leave as is
PostPosted: Fri Dec 12, 2025 8:08 pm
Ok gold finger both sides, slight gold plating other end and heat sink and transformers can be removed. At that point what would you think? And i appreciate you taking the time to help out. I am here to learn
PostPosted: Fri Dec 12, 2025 8:46 pm
Definitely high peripheral at minimum.
I do think these have a shot at low Telco, especially the two with the extra gold plating but I'm not 100% sure.
