It is currently Mon Aug 03, 2026 8:27 pm
 Post subject: Opinion on boards
PostPosted: Sun Dec 14, 2025 1:25 pm
I usually use my educated guess on boards but considering I have hundreds of each I prefer to have a second opinion thanks folks attached is photos each photo is from and back of the board. Also I have these pins that have gold tips not full gold plate. What to do with them?
 Post subject: Re: Opinion on boards
PostPosted: Sun Dec 14, 2025 5:54 pm
Assuming front and back on all the pairs.
Low peripheral
Midgrade
Gold plated pins*
High peripheral
*depending how much work you're willing to do you can either try to sort any pins you get by how much gold you can see or (I guess and/or really) trim the gold plated bit from the non plated to get the most gold per weight. Boardsort typically gets their XRF gun out to check pins to give the most accurate payout. Pale yellow on a limited amount of the pins will be some of the lowest gold/weight. The deeper the yellow color gets, typically the thicker the plating and obviously the more surface area plated there's more gold on the pin. I try to sort any pins I get roughly by:
Little surface area and thin plating,
More surface and thin plating to little surface area and thick plating,
Most/all surface area and solder/other low value stuff, and
Clean pins fully gold
PostPosted: Sun Dec 14, 2025 9:27 pm
Thanks for the response! we were the same on opinins but the second i wasnt sure if the amount of ic chips on the back countered the cable connectors on the front.
