PostPosted: Mon Nov 02, 2015 4:23 pm
sorting to send the next telecom boxes. this are part of the ones i want to be sure. Regards,,,
PostPosted: Mon Nov 02, 2015 4:51 pm
6 is borderline. Could go either way.
You could Go telco but i would put it with peripheral.
1 looks good despite the small transformer.
Rest are telco.
PostPosted: Mon Nov 02, 2015 5:39 pm
Thanks` I`ll keep posting my borderlines. the ones that do not pass telco will be depopulate and sort parts for flat rate boxes.
PostPosted: Tue Nov 03, 2015 10:26 am
In my experience, it is really going to depend on who does the sorting. Some of the guys grade a bit more strictly than others. I would say most of those are going to be better than peripheral, but not quite telecom.
When I take in material like this in, what I do is set it aside from all my sorted stuff. I ask them if they could give me a grade on said boards as I think they are better than peripheral, but unsure if they qualify for a higher grade. They then sorted them for me... on the last batch, they gave me peripheral for about half, one of the higher motherboard grades for some, and telecom for two of the boards.
Sorry it is not a solid answer, but that is the best advice I can give you... You could always send an email to Chris.
PostPosted: Tue Nov 03, 2015 10:38 am
That was a better way to put it than i did.
2 4 7 8 are definitely telco
1 should be. You have a C20 and an 80xxx silver pin (dont remove the socketed ic)
3 and 6 are either large socket or telco. Depending on scale master.
5 on a good day could fetch telco but again i would go peripheral or small socket for it.
NOTE #8 top right remove that plastic box. Has lithium battery in it.
