It is currently Tue Mar 17, 2026 6:38 pm
 Post subject: Low grade peripheral??
PostPosted: Fri Jan 09, 2026 1:51 pm
Last post till later. Thank you in advance for working with me. Do these boards meet the mark for low grade peripheral?
#1 heavy gold pins at end not much more
#4 gold connector
#6 a few gold pins
PostPosted: Fri Jan 09, 2026 4:00 pm
I would submit all at Low Peripheral. With that said. Not every DIP package is " what it seems to be." Some are just resistor packs. Transistor arrays. Bridge rectifiers. Optical couplers. Solid state relays. Not an IC chip. As commonly understood in escrapping. As it is. In other words. The DIP chip doesn't have the conventional gold wires connected to the die contained in the package. I am sharing this only because PCB 3 and 4. Fit what I am sharing( my opinion) . No real IC there. But. With the gold pin connectors. I see Low Peripheral for all.
