It is currently Mon Aug 03, 2026 8:21 am
PostPosted: Sun Jan 11, 2026 3:45 am
How should I think about boards with screens on them? The picture shows the front of a board with the screen, then the front without the screen, and the back of the board.
What would the grade be before and after removing the screen?
PostPosted: Sun Jan 11, 2026 1:49 pm
If the chips are visible with the screen on i would say low grade peripheral, with it off i would say high grade peripheral. I wouldn't take that to heart though. I'm still learning boardsorts grading so i would put it in low peripheral. I haven't shipped anything to them yet but from what i've read, they sort everything when it arrives.
Ryan Keller
Keller's Custom Services
PostPosted: Sun Jan 11, 2026 2:07 pm
Certain displays can add value to a board but in this case you should be removing the screen. The steel frame usually has bent tabs on the back that you can bend back and pull off easily and then get the screen off too.
