It is currently Thu Oct 01, 2026 3:09 am
 Post subject: Laptop boards
PostPosted: Fri Jan 30, 2026 8:21 pm
Do these go as integrated motherboards or high peripheral?
 Post subject: Re: Laptop boards
PostPosted: Sun Feb 01, 2026 12:27 pm
Those are without a doubt Laptop Boards. I would submit them to Boardsort in the Laptop Category.
PostPosted: Sun Feb 01, 2026 1:09 pm
They def came from laptops but they aren’t socketed processors so doesn’t that put them in the integrated motherboard category?
PostPosted: Sun Feb 01, 2026 1:29 pm
This might have changed, but previously if it was the mainboard out of a laptop, it went as a laptop mobo even if the CPU was soldered/no socket.
PostPosted: Sun Feb 01, 2026 1:50 pm
The green board has a GOLD Tab BGA chip on it. If you look at the Integrated Motherboard category. It makes a note. NO BGA. That upgrades that green board. I still think Laptop Motherboard.
Also. For now. Clean that heatsink paste off the one chip on the blue board. I want to look it up. Also remove the shield in the corner. Should be chips under the shield. Then. Please repost the blue board.
As a sidenote. You could email Chris about those 2 boards also. I can't wait till O.S.C.A.R. comes back.
PostPosted: Mon Feb 02, 2026 4:35 pm
The shield on the blue appears to be an integrated wifi card, so definitely cos under that.
Anything on the other side of either board?
I concur with what's been said already, generally laptop boards will stay as laptop. As things get miniaturized more and more and it takes less valuable material to build computers, the value of scrap will definitely change. The Dell board looks a little older/better materials compared to the blue one, which may be new enough to be less valuable. But does it dip out of laptop grade..? ¯\_(ツ)_/¯
