It is currently Sun Aug 02, 2026 3:54 pm
 Post subject: RAM? No Idea….
PostPosted: Thu Feb 12, 2026 7:38 pm
From Digital Equipment Corp server. 1983
Is this gold dinger RAM? Should I pull the Huge ceramic ICs?
Images are front and rear of the same 9” x 14” board.
 Post subject: Re: RAM? No Idea….
PostPosted: Thu Feb 12, 2026 8:18 pm
High telco, do remove the steel brace and if you can easily the plastic pulls.
Ceramic chips soldered? If yes, don't remove the pins will have solder on them or you'll lose pins and lose value. If not, then yes you can pull them.
I'll look real quick to see if I can find anything but if the ceramic chips have a gold cap underneath it would jump to Gold Cap Chip Board. If I can't find anything or if you see this first and want to check, drill a small hole on the back side of the chip so you can see underneath.
PostPosted: Thu Feb 12, 2026 8:24 pm
Good chance there a gold cap.
reference
Could still drill that small hole to verify.
PostPosted: Thu Feb 12, 2026 10:35 pm
Drill the hole into the backside of the board where the ghost squares are, where the chips lay on the other side of the board.
You drill the chip, it's getting prorated.
PostPosted: Fri Feb 13, 2026 9:58 am
I'm all chips in on high grade telecom on this one personally. That's a good looking board you have there.
Abbreviations
HGT - High Grade Telecom
LGT - Low Grade Telecom
HGP - High Grade Peripherial
LGP - Low Grade Peripherial
MGB - Mid-Grade Board
LGB - Low-Grade Board
