It is currently Thu Jun 11, 2026 5:00 pm
PostPosted: Sat Feb 14, 2026 12:37 pm
And what should i do with it, process it or leave as is?
PostPosted: Sat Feb 14, 2026 1:02 pm
Personally I would leave as is for midgrade.
It really comes down to your goals and time. If you have lots of time there's nothing wrong with pulling more stuff off boards, but if you don't know what to do with all the individual components I would avoid cleaning a board completely. If you have lots of material to get through and not a lot of time, you need to just get boards to a point where Boardsort will accept them. If your somewhere in between, you can get to choose how much you have time for.
If you have time to spare...if you're able to easily remove heatsinks (these don't look particularly friendly) you can always do that. The largest board soldered onto the main board could probably be pulled for low or high peripheral depending what's on it. You can pull copper off toroids. You can remove capacitors and so on.
PostPosted: Sat Feb 14, 2026 6:58 pm
Can you safely seperate the different boards? If so you might be able to get the junk off on the side with the gold connector... Remove all of those capacitors, coils and transformers and it might cumulatively qualify as HGP
Abbreviations
HGT - High Grade Telecom
LGT - Low Grade Telecom
HGP - High Grade Peripherial
LGP - Low Grade Peripherial
MGB - Mid-Grade Board
LGB - Low-Grade Board
PostPosted: Sun Feb 15, 2026 1:18 am
The only power supply you want to break down are the server ones with gold finger push ins.
ANY other power unit really isn't worth the time/payout. Sell as is, with wire, for a decent rate; If anything, cut some of the gold connector ends off the ones where it doesn't affect losing wire weight.
