It is currently Wed Sep 23, 2026 6:09 pm
 Post subject: High grade telecom?
PostPosted: Sun Feb 15, 2026 8:18 pm
Are these considered high grade telecom even though the socketed IC chips have been removed? I would think the one with the processor looking things is high tele, but not sure about the other two? Thank you in advance
 Post subject: Re: High grade telecom?
PostPosted: Sun Feb 15, 2026 9:51 pm
The ICs are one of the primary contributors of value in telco grades. It looks like there is lots of gold contacts where the ICs were.
I would lean high peripheral on the larger boards and low peripheral on the smaller.
The two Altera chips look ceramic. I would carefully pop those out and see if they have a gold cap. If they do, you can go gold cap chip board on it or weigh both the chips and the board and see if there's a benefit to removing one or both.
PostPosted: Sun Feb 15, 2026 10:21 pm
Beat me to it marked141, Check those ceramic IC socket ones for possible gold caps; they would be 386/486 class if so. Suppose they're not, still remove all the socketed ICs and put in your IC pile or separate.
I would bump the boards a little more, I feel those old sockets are better.
Boards have gold fingers on both sides too.
say , Low per/ High per on 52, Low tel 51, Low tel 53
PostPosted: Sun Feb 15, 2026 10:56 pm
Thank y'all for the help! I will definitely remove the chips to see if they are gold cap on the bottom
