It is currently Wed Sep 23, 2026 6:33 am
 Post subject: Troffer Light Boards
PostPosted: Mon Feb 16, 2026 4:37 pm
Curious what people think the grading of this board should be. I got my hands on about 25 troffer lights and each one had this board.
There is quite a bit of visible gold, but also has transformers and other junk. I was thinking maybe low Peripheral as is and high peripheral if the junk was cleaned off? What do you think?
 Post subject: Re: Troffer Light Boards
PostPosted: Tue Feb 17, 2026 12:39 pm
Mid grade.
Cleaning this board wouldn't be worth your time/profit. The weight in the items that would have to be removed such as, ferrite posts, electrolytic caps, and the Cu trans, is prob most of the board itself.
Those removed it could barely clear into Low per
PostPosted: Wed Feb 18, 2026 7:44 pm
I agree. This in its present condition is a MGB... If you really are interested (Like I would be) ... Depopulate the board of the junk. It'll probably be 25-30% of its original weight but you have a LGP board. It won't be worth much so it is honestly up to you on what you do here.
Abbreviations
HGT - High Grade Telecom
LGT - Low Grade Telecom
HGP - High Grade Peripherial
LGP - Low Grade Peripherial
MGB - Mid-Grade Board
LGB - Low-Grade Board
PostPosted: Thu Feb 19, 2026 2:36 am
Thank you, I agree with you both. Not sure what I was thinking at the time but definitely not peripheral with the junk. I am not located within driving distance so everything needs to be shipped. I will depopulate and grade as PLG, as shipping a mid-grade board is a break even situation at best.
