It is currently Sat Nov 07, 2026 2:10 pm
 Post subject: LED MODUALE TILES
PostPosted: Sat Feb 28, 2026 1:12 pm
[color=#8080FF[/color]
Which classification would these be?
How much do you buy these for?
 Post subject: Re: LED MODUALE TILES
PostPosted: Sun Mar 01, 2026 10:39 pm
We never did get anywhere with a similar set of boards from someone else...
viewtopic.php?f=4&t=24281&p=51149&hilit=Display#p51149
You would want to remove the excess plastic on the two and what looks like mounting points on the one to get the best rate for them.
I'm curious, haven't seen this type board in person myself, can you get pictures a little closer and at an angle of both sides? Doesn't have to be all three boards, just trying to better understand what's there and the thickness of the board.
PostPosted: Mon Mar 02, 2026 7:40 pm
From what I have learned is that this P2, high resolution. High grade indoor panels.
PostPosted: Mon Mar 02, 2026 8:14 pm
So just some different thoughts:
Is there a material coating the LEDs?
Any gold on any of those connector pins?
The board is much thicker than I expected. Could be good if multiple copper layers or could be bad if no layers.
Remove the wire.
Remove the magnet if it'll pop off.
I'm kinda in the same boat I was in with the other post, high peripheral to high Telco seem possible depending on different factors.
