It is currently Mon Jul 27, 2026 7:35 am
PostPosted: Thu Dec 11, 2025 3:00 pm
Photo of the relay. My assessment. Remove plastic covering. Take out solenoid and metal. Then submit as Connectors. Nope. Not for resale. Going to scrap.
I figure this is the most efficient and profitable method.
PostPosted: Tue Mar 03, 2026 12:19 am
When I am board I will scrap relays but it needs to be a lot so I can get into automatic mode.
PLast Scrap
External Connectors copper or brass
Internal Contactors - Silver
Coil - Copper Transformer
Have fun
PostPosted: Tue Mar 03, 2026 2:02 am
I see plastic, steel, copper and brass for sure. Then, unless the color is off, you've got gold pins and whatever material the contacts are made of, which can be silver or contain some.
The clear plastic should pop off fairly easily. The copper windings should slide off a steel post, possibly after bending some other steel, then you could unwind the copper off any plastic. Contacts might be able to be cut/pulled off here otherwise... Everything else is probably embedded in the black plastic, may require percussive persuasion to free.
PostPosted: Wed Mar 04, 2026 5:19 am
Those are definitely worth complete disassembly. Plastic pops off. Entire pin and blades and contact gold plated. Contact soft silver. Blades held together with slender screws that your sidecutter pliers will easily snip, then blades and contacts are loose and free. Copper coil slides off post easily once the plastic top is snipped. Note: not all relays have the gold plating. Some are standard and have hardened silver contacts.
