It is currently Thu Jun 11, 2026 2:40 am
 Post subject: Depopulating??
PostPosted: Fri Nov 20, 2015 5:11 am
I have a question about computer motherboards. Would it make sense to remove the jacks from the board for packaging reasons? Also if they are valuable then could you just send them along with the boards? Or is the best course of action to leave things as is?
 Post subject: Re: Depopulating??
PostPosted: Fri Nov 20, 2015 1:18 pm
The way i so it is snap the boards in half and use a bit of Scotch tape to hold the halves together.
Removing the jacks could bring it down to peripheral grade easily... or worse.
PostPosted: Sat Nov 21, 2015 1:10 am
Good idea. I wouldn't have thought about that. Thank you. I will try it
