It is currently Mon Oct 26, 2026 12:30 pm
 Post subject: SCSI HDD question.
PostPosted: Thu Mar 05, 2026 7:07 am
Did some searching and found that scsi boards are considered high grade?
I just want to know before I start taking them apart do I for any reason need to remove the plastic connector? I got a good bit of them like this one.
 Post subject: Re: SCSI HDD question.
PostPosted: Thu Mar 05, 2026 9:55 am
Yup, almost any hard drive board that isn't SATA that's attached to a hard disk drive will be high grade hdd board.
All you need to do is remove the board from the driver, shouldn't be anything on the board to remove
