It is currently Wed Sep 23, 2026 1:09 pm
PostPosted: Fri Mar 06, 2026 2:44 am
I'm curious if I'm on the same page as everyone else, or if I have it all wrong. I'm new at this, so please bear with me.
I would put this board at Low Grade Telcomm as it is.
The two transformers and Mosfet with attached aluminum heatsink (marked in green) I expect are the biggest detractors. Is there anything else that could be done to push this board up to Telcom high? or is the chip density not quite there?
Also, the two marked chips are socketed in some of the boards. How would removing these chips sway the board rating?
No visible gold on this board
Back side is empty as pictured
Are there any other points of interest that I should consider in handling these?
Thanks in advance for your input, even if you feel I have it flat out wrong. I'm hear to learn, one way or another!
PostPosted: Fri Mar 06, 2026 9:47 am
I'm leaning high peripheral as is and don't know that removing anything would change it.
PostPosted: Mon Mar 09, 2026 2:12 pm
I received final word, boardsort rated the boards at peripheral low. I shot an email off to Chris to find out what it would take to push them to high peripheral, but he hasn't got back to me yet.
PostPosted: Mon Mar 09, 2026 3:30 pm
I hedged a bit in saying high so thanks for the update on being low.
The switches (dial/slider) might add some value so I wouldn't remove those and removing the heatsink and transformers may or may not be enough to push it up. Feel free to share if Chris gets back with additional info.
PostPosted: Mon Mar 09, 2026 3:57 pm
Okay, just got final word back on these.
Chris highlighted a combination of No visible gold and chip density too low, so even cleaned they will never rise above Peripheral Low grade.
Also, in regards to pulling the two socketed chips, the official response is, and always will be "Removal of chips can risk the board being downgraded."
PostPosted: Mon Mar 09, 2026 4:25 pm
That makes sense.
I honestly still have no idea which ICs are socketed, they all look like they're soldered
PostPosted: Mon Mar 09, 2026 5:07 pm
marked141 wrote:
That makes sense.
They are in this example. You are correct, the chips in the original photo are soldered. I think in this instance, it's a case of a hardware revision, where a later revision had them soldered and older revisions had them socketed.
*Edit: The extended length of the board isn't relevant to it, it just happens to be a physically larger variant of the same model phone. Extended, with more buttons essentially.
