It is currently Sat Nov 07, 2026 1:59 pm
PostPosted: Sun Mar 22, 2026 2:16 pm
Plastic IC chip with Gold Legs? Did I finally get one right?
PostPosted: Sun Mar 22, 2026 2:46 pm
close-ish...plastic ICs tend to be black
Key things to notice here:
Green fiber, note the color of the board the pins and cap are mounted to.
Metal cap, kinda like a gold cap but no gold, it's mostly copper but isn't worth removing even if you could do so without damaging the CPU
Gold Pins, what's called a PGA chip, Pin Grid Array.
So, green fiber with metal
PostPosted: Mon Mar 23, 2026 10:46 am
Marked 141, I'm a little bit rusty on cpu, but why is this not a no pin cpu?
PostPosted: Mon Mar 23, 2026 11:01 am
Zoom in on the first picture. Those are pins, some are even bent a little so you can see them better
