It is currently Sat Nov 07, 2026 12:32 pm
 Post subject: need graded please
PostPosted: Fri Apr 04, 2014 7:39 pm
I dont remember where they came from
 Post subject: Re: need graded please
PostPosted: Fri Apr 04, 2014 7:51 pm
One more this is brown on the back but appears to have gold contacts any ideas?
PostPosted: Fri Apr 04, 2014 9:24 pm
low-grade .HOWEVER if contacts are large enough i have chopped them of and put them with the Gold Tip Connector Ends pile.
as for the HP OfficeJet card i dont know about that(1st pic 1st post)
as for the other that i would throw in the mid-grade pile..(2nd pics 1st post)
PostPosted: Fri Apr 04, 2014 10:27 pm
Maybe a second photo of the back side of those cards in your first post will help us better determine board grade.
PostPosted: Sat Apr 05, 2014 5:54 pm
Backs
PostPosted: Mon Apr 07, 2014 10:41 am
the board on the right is mid-grade. The one on the left I'm going to leave to boardsort as it does show some brown, but appears to have silver plated on it, so I can't determine if it would go as low grade, mid-grade, or even peripheral grade.
PostPosted: Mon Apr 14, 2014 4:08 pm
I would buy both of those boards as Peripheral Grade. The small one has a slight population on the one side, and the larger looks to have a bubble IC in the middle.
If you have a whole bunch of these I would ask that you give me a chance to look into the values a little closer, but if you only have a handful then Peripheral Grade they are.
Thank you for the look,
PostPosted: Mon Apr 14, 2014 8:02 pm
Only a handful I'll throw them in the periphial pile thanks
