It is currently Sat Sep 26, 2026 1:40 pm
 Post subject: Actuator boards
PostPosted: Fri Apr 10, 2026 11:06 pm
Found these two types of boards in actuators. In an open top, with renovation material.
I removed one large and three small capacitors from the top board.
I removed one transformer and several capacitors from the bottom board.
Will the bottom make high peripheral?
Top looks like high peripheral to me. Am I in the right neighborhood?
Thanks, LindyLou
 Post subject: Re: Actuator boards
PostPosted: Sat Apr 11, 2026 5:41 am
If those contacts are gold plated. On the bottom PCB. Submit to High Peripheral.
My evaluations are my own
PostPosted: Sat Apr 11, 2026 11:06 am
The first has enough going on that I'd probably stick it in at least low Telco.
I'm guessing the terminals on the second board are nickel plated brass, which is gonna add a fair bit of weight relative to the board. So I think I'd lean low peripheral there.
