It is currently Mon Oct 26, 2026 10:32 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 17 posts ]  Go to page 1, 2  Next
 Post subject: What's inside it part 2
PostPosted: Thu Dec 03, 2015 12:27 pm
Dreamcast controller and vmu
The raw memory cards are peripheral as posted.
The actual visual vmu will be telco once you remove the tiny screen
The controller's board is peripheral
The cable end is gold connector
PostPosted: Thu Dec 03, 2015 12:46 pm
Leapfrog portable edutainment system.
Internally it is a Nintendo gameboy advance
The board is peripheral. You have the silver and rhodium mylar from the screen. An lcd screen. The led backlight ribbon. Some small wires steel and plastic
PostPosted: Thu Dec 03, 2015 1:01 pm
Code:
Edit]I just got an update from Chris today.
The little micro DLP units, both fibre and ceramic, go in the peripheral class boards, not respective DLP classes. [/edit]
By request: step by step disassembly of a CD/DVD laser head assembly
PostPosted: Wed Dec 09, 2015 4:28 pm
Tivo series 2
PostPosted: Wed Dec 09, 2015 4:33 pm
Hifi VCR VHS deck
Lots of scrapyard stuff. Not much for boardsort.
Remove board. Yank out motor and heads. Cut screen off. Sell board whole.
PostPosted: Fri Dec 11, 2015 4:26 am
AT&T Uverse wireless converter box
Pay attention to the screws. They're neither hex nor torx but "security star" size 6 inside size 7 outside
You're definitely not supposed to get in one.
Dont miss the silver signal sink. It's pure silver laminate.
PostPosted: Fri Dec 11, 2015 4:31 am
286 laptop
This unit has multiple variants in 286 and 386 varieties. Aside from the cpu they're identical. The 286 in this one went moto/foreign gold cap. It's not pictured
PostPosted: Fri Dec 11, 2015 9:49 pm
Ibm wordpad cellular c3
Not much hear but it's better than nothing. Was a paperweight for a while. ;)
PostPosted: Fri Jan 01, 2016 2:14 pm
Smart power strip with surge and brown suppression.
PostPosted: Fri Jan 01, 2016 3:20 pm
Cardscan 300 id/credit card scanner
Basically identical to the brother/lg lamination machine.. the heat bar replaced with a scanner bar.
Along with what's posted the bars are 308 stainless with brass mounts. Small sealed motor.
Bunch of plastic.
