It is currently Fri Jun 19, 2026 1:16 pm
 Post subject: i need help
PostPosted: Sun Sep 28, 2025 5:40 pm
what category is this board in
 Post subject: Re: i need help
PostPosted: Mon Apr 20, 2026 12:28 pm
High Peripheral.
PostPosted: Mon Apr 20, 2026 12:29 pm
idk it might be able to sneak into low teclo
PostPosted: Mon Apr 20, 2026 12:41 pm
I think your right. I assumed the blue edge connectors were not gold plated. I did my best to zoom the image. (Blurry pictures are blurry evaluations). I think I can see gold. So. Yep. I would submit Low Telecom. Also. Nice follow up. Austin86.
Here to learn like everbody else
My evaluations are myown opinion
PostPosted: Mon Apr 20, 2026 1:01 pm
Not going to lie, I did not even look at the pins in the blue connectors... I saw a bunch of chips and was like yep might be telco.
PostPosted: Mon Apr 20, 2026 2:17 pm
I'd be leaning high Telco, lots of chips and gold pins.
PostPosted: Mon Apr 20, 2026 3:44 pm
even with the blank spot of pcb and the two likely non gold pin connectors with the plastic and that steal bracket ?
PostPosted: Mon Apr 20, 2026 5:14 pm
Steel bracket? Around the 4 pin power connector?
If the board didn't have the RAM(???) sockets on the one end I'd probably mistake it for a high grade hdd board.
PostPosted: Mon Apr 20, 2026 6:03 pm
yes the one by the 4 pin. I think it's a board out of a old camera system, axis is a common brand in enterprise camera systems.
ether way i thought it would be low telco because of the plastic and blank spots, the steel braket I kinda just tossed in there. idk the more i think of it the more i realize it's probably high telco. im goiyon no sleep for the last 32 hours so im running empty lol
