It is currently Thu Sep 10, 2026 12:56 pm
PostPosted: Fri Apr 24, 2026 11:45 pm
Hi there,
I swear I saw a video once on how to process the yellow and black tantalum, but I cannot find it on your youtube or on your site. It showed how you had to remove the "legs" on either side of it before you send it in. Is that true? Is that why it is a "blue," complex item?
Thank you,
Justin
PostPosted: Sat Apr 25, 2026 4:08 pm
The class is complex because not every yellow and black square is tantalum.
It’s not a class that general scrappers are going to get correct.
PostPosted: Sat Apr 25, 2026 4:22 pm
Oh dang. So, for the low price per pound and how many it takes to get per pound it doesn't seem worth it for either party.
PostPosted: Sat Apr 25, 2026 7:59 pm
I highly recomend this You Tube video. Sharkscrapper. A lot of good information. On your question.
I do not pull MLCC from boards. Though tempting. Like lostinlodos said. "COMPLEX"
https://youtu.be/vFQADwDgshA?si=91CdwLRRtshLSlIa
PostPosted: Sat Apr 25, 2026 10:05 pm
Shark is great and boardsort pushes him.
I also suggest Moose
PostPosted: Sat Apr 25, 2026 11:01 pm
Ok, I will check it out. Thank you!
PostPosted: Sun Apr 26, 2026 1:35 pm
BS wants you to remove the legs even with the SMD. They easily bend off and break flush with your hands.
Yellow and black only. They will all have a positive marked line and a "+" inline with the mark. Don't get this confused with regular capacitors or electrolytic caps. They will all be square.
Tantalum comes in DIP caps and in line resistors as well but BS only buys them if tested and quantity permitted.
It's not worth removing Tantalum. Takes a lot to even get a lb. This is more for over stock and companies with outdated materials that have stock.
PostPosted: Sun Apr 26, 2026 7:28 pm
Ok, that makes sense. I won't waste my time collecting them.
