It is currently Sun Aug 02, 2026 12:53 pm
 Post subject: photos will not load
PostPosted: Sun Apr 26, 2026 7:41 pm
I don't understand what Im doing wrong. I cant see any photos on forum - says Im not authorized
I cant upload photos either to get ID help. It pretends its going to but just doesn't do it. says uploading for hours. 1 mb picture is all
Searched for answers but no luck. I just need advice on a few boards. Maybe its my phone? I dunno, pictures loaded before tho & I haven't changed any of my settings. also videos wont either
 Post subject: Re: photos will not load
PostPosted: Sun Apr 26, 2026 10:02 pm
Are you a registered member? If not. You will not be able to do quite a few things. Namely. Some of the things you just mentioned.
PostPosted: Sun Apr 26, 2026 10:21 pm
I am & I could see the pics before I registered. Im more concerned about not being able to load my photo because I want to confirm a few boards before I mail in my box.
PostPosted: Sun Apr 26, 2026 10:27 pm
You must first Choose File then Add File. It is a 2 step process.
PostPosted: Mon Apr 27, 2026 12:06 pm
Sometimes the site does weird things, Lostinlodos made some suggestions here
If the upload process is causing confusion you hit choose file:
Based on your computer/phones options select from files/take an image/etc.:
Once you've picked or taken the image you want, you can add a name or description and select add file:
Note* a poor internet connection can cause uploads to fail at this point, be sure you have a good signal or connect to wifi.
PostPosted: Wed Apr 29, 2026 2:53 pm
So its got to be my connection. My area is very poorly served & my house in particular is a dead zone Although now I can see images again on the posts occasionally. Iv decided Im just gonna send the things Im certain of for now.
Theres really no competition for other internet services. I live in a small town in Montana. Anyways just posting to say I appreciate the help. I didn't solve the problem but it did clarify what the problem is. I dont ever upload things so I didnt realize the obvious of why it kept failing
PostPosted: Wed Apr 29, 2026 3:21 pm
Two suggestions if you want to try and figure out the scrap value still:
Search for the board online and give a link.
Or describe the board, how big it is, what it came from, what's on it, etc...
PostPosted: Wed Apr 29, 2026 8:16 pm
I had the same problem. For me, it turned out to be a resolution issue. The file was too large. To fix it, I resized the picture using "paint". I reduced the size and was able to load it, the second time around. If you need to know how, follow these steps:
1. right click on your photo and choose "open with"
2. choose "paint"
3. at the top look for "Resize and Skew" (it vaguely resembles a Picture in Picture icon)
4. Choose "pixels" and adjust the Horizontal and Vertical to something smaller. I believe I used 1102x1080
5. Resave your new photo
6. Try to upload to the forum again.
Good Luck!!
PostPosted: Thu Apr 30, 2026 11:26 am
True! Image size can cause issues, if you're on a phone, instead of pc, and get that you can sometimes take a screenshot of the picture you took and end up with a lower resolution that will upload
PostPosted: Thu Apr 30, 2026 2:41 pm
I experienced the same thing when I worked on a farm located between some hills. The dead zone was right on the farm. But I found out. That if I went about 200 yards up the hill. I could get good solid reception. Maybe you can get reception with just a short walk or drive. Upload your photos. Get er done. So. To speak.
I did download my carriers phone coverage map. Sure. Enough. A small little dead zone right at the farm. That phone company did its job making that map. Download your carriers map. See whats up.The farm house had a landline. But. I had no access to that. But later. I repaired the phone circuitry in the barn. And then had reliable phone service. So maybe get a landline. Get WIFI. And you can use your cell. Or go with cable phone service. Or go with a satellite phone. Thats exactly what they are for. Remote areas. I know Montana is way different than here in West Pennsylvania.
You solution probably will be unique.
I probably didn't tell you anything you don't know already.
