It is currently Mon May 25, 2026 4:32 am
 Post subject: Connector Ends
PostPosted: Tue May 05, 2026 4:06 pm
I understand that some of these things may not qualify but I planned to put each of these three things in with connector ends. Does that work? Are they really something Boardsort accepts? Are they something else? Thanks, Gizz
 Post subject: Re: Connector Ends
PostPosted: Tue May 05, 2026 7:51 pm
If they’re gold. And an end. They’re gold connector ends. But you basically have trimmed gold fingers mixed in there which would be a higher grade
PostPosted: Tue May 05, 2026 8:53 pm
Ignore this (Right the gold you're cutting off of boards are what's called gold fingers) Lost has a better eye for these, especially once they're off the board, the connectors with pins are connector ends. You do want to trim as much of the green off the gold fingers as you can manage. Boardsort is able to pay as well for them as they do when everyone removes as much waste material as possible.
PostPosted: Wed May 06, 2026 9:13 am
Those are not gold fingers
They are Gold markings from the edges of boards
This is considerably more board and considerably less Gold, they go as high peripheral
PostPosted: Wed May 06, 2026 9:16 am
This is considerably more bored and considerably less Gold, they go as high peripheral
Ah you’re right! My mistake.
PostPosted: Wed May 06, 2026 9:33 am
wait they do??? I have a bunch of it and I'll need to send it in lol.
PostPosted: Wed May 06, 2026 1:45 pm
Nearly any board with these gold trim markings is already high peripheral or better, so cutting the flashing off for high peripheral is not profitable.
PostPosted: Wed May 06, 2026 1:55 pm
I should restate:
There are what look to be memory card ends. If they are clean and have no plastic or metal those can get clean gold finger.
Those square blocks though are simply high peripheral.
I wouldn’t make a habit of doing this though. I’m not sure to what extent of volume the limit is here, as it’s an off/over processed material.
I only sent this stuff in from blade power supplies since I can process those boards to a better payout myself than selling to scrap here, but wind up with a blank board in the end worth midgrade, aside from the gold flashing.
How Chris would value 10lbs is an unknown, the most I ever sent was a few ounces or so at a time, along with pounds of high peripheral.
I’m kinda bending the rule that anything that WAS previously peripheral when the peripheral class split would remain as high peripheral.
PostPosted: Wed May 06, 2026 2:49 pm
nearly any... but not all
