It is currently Sun Aug 02, 2026 9:13 am
PostPosted: Sun May 10, 2026 7:59 pm
Hi everyone,
My client gave me, with a signed contract to recycle, 300 D-link routers/switches.
I am torn between low or high peripheral because there is a little blue clip tray that pops out. I was going to email Chris but I figured let me ask here first. All are virtually identical.
Heat sinks will be removed. Metal shell will be removed. Pictures of 1 I took apart for reference. Thank you for any help !
PostPosted: Sun May 10, 2026 8:03 pm
Main board, removed from case and aluminum heatsink removed, high peripheral
I can't recall on the optical module where those have gone. The shell is likely a Zinc alloy.
PostPosted: Mon May 11, 2026 9:30 am
Thank you!
I emailed Chris just to be safe considering the volume I will be sending.
Chris confirmed high peripheral for the main board. The thumb drives goes into connector ends.
PostPosted: Mon May 11, 2026 9:38 am
I recall someone saying they throw those blue clip module trays in connector ends as is. I take mine apart, but Marked141 is correct the bottom casing is a zinc alloy which I toss in die cast pile for my local yard, don't recall if top shell part is stainless or not. Been a while since I took one apart and don't remember what the board looks like but I think I usually add them to high peripheral.
PostPosted: Mon May 11, 2026 8:55 pm
I did not see an easy way to take the thumb drives apart easily.
Also, the heat sinks on the main board are really glued/pasted on the chip. I worked on 4 today. 1 chip came off with the heat sink and the other 3 stayed on the board. Rather defeated at this point as I am at a loss to what to do.
PostPosted: Tue May 12, 2026 6:59 am
I have used heat to loosen up that glue. A few seconds under a heat gun. I have heard that cold can work too but I haven't tried it.
PostPosted: Tue May 12, 2026 9:32 am
Yup heat gun or propane torch or similar, just be careful to direct the heat at the heatsink. You can just tape that popped IC back to the board
PostPosted: Tue May 12, 2026 9:35 am
You all rock! Thank you so very much for this information. My dad and I were so worried we messed up with these boards.
I am so grateful for this community. Thanks again everyone.
