It is currently Sun Oct 25, 2026 7:23 am
 Post subject: Yes / No
PostPosted: Sat May 09, 2026 10:05 pm
I have a bunch of these ribbon wire connectors, & I see what appears to me, to be a small circuit board maybe sandwiched in there??
Should I take these connector ends apart to separate the boards or just leave them as they are and sell it as connector ends???
Thanks
 Post subject: Re: Yes / No
PostPosted: Sat May 09, 2026 11:25 pm
Connector ends as is is probably fine. If you wanted to take one apart to see exactly what's there you could also do that.
PostPosted: Sun May 10, 2026 1:11 am
marked141 wrote:
Connector ends as is I'd probably fine. If you wanted to take one apart to see exactly what's there you could also do that.
thx
PostPosted: Sun May 10, 2026 12:51 pm
Don't worry about breaking it down or removing the board. That board has the pins attached to it so they don't bend or move.
Almost looks like there's two connectors , connected together.
PostPosted: Sun May 10, 2026 1:15 pm
Similar applications are like those memory card or flash readers. How they have that little green board and the pins are soldered to it and pushed into the framing.
PostPosted: Sun May 10, 2026 2:14 pm
Good as is for connectors
PostPosted: Tue May 12, 2026 3:25 pm
Are you also in the microscrapping group on facebook? I literally just saw a guy have one of these taken apart and I commented with gold connector ends.
Possibly just a coincidence.
PostPosted: Sun Jul 26, 2026 3:12 am
nope, it wasn't me. I really don't do the whole FB thing still. I hate trying to find my way around all of the different options to things on there...
