It is currently Sun Aug 02, 2026 4:15 am
 Post subject: What grade?
PostPosted: Sun May 17, 2026 7:07 pm
I’m thinking low peripheral, but I’m not certain.
 Post subject: Re: What grade?
PostPosted: Sun May 17, 2026 8:52 pm
If what's left of the wire terminals isn't steel I'd do low peripheral, if it is steel, mid grade
PostPosted: Mon May 18, 2026 7:21 am
Thanks Marked. I’ll test later and see. I did remove quite a bit of “junk” already. Some copper items that were heavy.
Couldn’t I remove those wire terminals alltogether?
PostPosted: Mon May 18, 2026 9:17 am
You could, would likely bring it closer to high peripheral.
If they're not steel they're likely brass, or less likely copper.
PostPosted: Mon May 18, 2026 12:38 pm
Yeah. Pull the 3 terminal blocks off. Remove the large electrolytic capacitors. Possibly the switch. Also those 2 pieces of metal on the left edge of the board. And. You have an empty IC socket. Put a IC in there. I think you will get High Peripheral. Just a thought.
PostPosted: Mon May 18, 2026 11:07 pm
Thank you both.
Update. The wire terminals are not magnetic. Probably brass. I will still remove them. I will remove the two large capacitors.
I should still have the socket IC in my bucket. I'll put that back in.
Thanks again for the help!
