It is currently Sun Sep 27, 2026 10:11 pm
 Post subject: What is this?
PostPosted: Fri Oct 25, 2024 11:07 am
Is this a high grade telecom or low grade?
 Post subject: Re: What is this?
PostPosted: Fri May 22, 2026 1:58 pm
It's Low Telecom unless you will remove the plastic. And the relays. In my opinion. Then submit High Telecom. That hefty edge connector should give you High Telecom.
My evaluations are my own
PostPosted: Sat May 23, 2026 9:53 pm
I agree with Austin. Remove the plastic and it's H.G. Telco. A lot of those relays contain gold plated contacts.
