It is currently Sun Sep 27, 2026 6:20 pm
PostPosted: Fri Sep 06, 2024 9:22 am
Not sure how to classify these two boards.
Board 1 is from a Sierra Wireless: AirLink LS300. I'm thinking maybe low grade telecom?
Board 2 are small boards with a CCD sensor and are about 2"x1.25" so not very big at all but I have a few. I'm thinking high/low peripheral?
I would appreciate any help on this.
PostPosted: Sun May 24, 2026 7:52 pm
Board #1 I would remove the screws and nuts on the connector. Then remove the other 2 threaded studs. I also would remove the sides of the shielding you left on the board. By experience. I know you can cut back the metal on the other connector. Just be careful. Leave the contacts. Doing that. You would definately secure Low Telecom. And. You may possibly get a High Telecom out of it. Considering the gold showing on the board.
Board#2 High Peripheral. Due to the known gold content of a CCD sensor. Also the other connector.
My evaluations are my own
PostPosted: Sun May 24, 2026 9:56 pm
As is I'd say 1 can go low Telco, if you clean all the way fencing from the shields without removing any of the goodies inside and pull the screws i think that's good for high Telco.
If the chip is visibly gold inside (the color is not great in the picture do you'll need to determine that) the glass then I'd lean high Telco there also.
