It is currently Fri Jun 19, 2026 8:36 am
PostPosted: Mon May 25, 2026 4:43 pm
Only 2 gold tab bga’s and a bunch of slots and ports. I’m still too new. Front and back images below
Thanks a ton in advance for any help/info/advice. VERY new to this realm. Be kind. Just trying to learn like everyone else.
PostPosted: Mon May 25, 2026 5:32 pm
Large socket motherboard.
That brown slot with the two black tabs folded down is where a slot processor would fit.
PostPosted: Mon May 25, 2026 7:05 pm
440bx boards are worth more as is then as scrap, they sell rather fast too
PostPosted: Mon May 25, 2026 7:54 pm
So what would I do with something like that or where would I sell that (ebay I would assume or is there a better avenue?)?
PostPosted: Mon May 25, 2026 8:11 pm
ebay is ok, amibay and the vcfed forms is anther place but both those sites you can't just walk in and sell, you'd have to post on the forums for a wile before you could sell anything. if you try to sell it put the bios ic chip back in it. if you have the cpu it could be worth more as it is depending on the model, the faster slot 1 CPUs are worth a good bit too. the slower ones are a toss up, some are like 5-10$ a pop at best and will sit for a long time, but the 700 mhz and faster ones are upwards to a 100$ with a few like the 100fsb 1ggz piii being worth a lot. this is assuming they work.
if the board doesn't work it's not really worth selling unless of its something special like the abit be6-ii 440bx board.
