It is currently Wed Jun 17, 2026 4:52 pm
 Post subject: Amplifier board
PostPosted: Sat May 25, 2024 9:47 am
This was pulled out of a Crown amplifier. What would it be classified as?
 Post subject: Re: Amplifier board
PostPosted: Tue May 26, 2026 5:22 pm
Mid Grade.
Here to learn like everybody
MY EVALUATIONS ARE MY OWN OPINION
PostPosted: Thu May 28, 2026 11:03 am
mid as cat said, remove the glue aroudn the big cap, on a side note the black mosfets with the white paste on them are mostly copper. i'm told some yards take them at number 2 copper. you could also take a handful of them, wrap them in a rag or put them ion a bag and whack them with a hammer to remove the copper backs off them.
If you have the time if might be worth going that route as mid grade is 50 cents a lb vs #2 being around 4$ a lb.
PostPosted: Thu May 28, 2026 5:06 pm
My yard takes the mosfets as dirty brass. You can, as mentioned above, remove the plastic and put them in copper number bucket.
My yard also takes capacitors as dirty aluminum. I am now getting into the habit of removing them from my boards. I don't believe this will hurt grading as there isn't any gold bearing material in them.
