It is currently Wed Sep 23, 2026 12:16 pm
 Post subject: Small Boards - Vol. 9
PostPosted: Sat Oct 22, 2022 11:02 am
My guesses:
A- high peripheral
B- low peripheral
C- low peripheral
D- high peripheral
E- high peripheral
F- high peripheral
PostPosted: Fri May 29, 2026 9:42 am
Small boards are hard to get excited about. But. There are so many significant small PCBs in all electronic equipment. They can be so frustrating to evaluated. At least for me.
Soooooo.
A High Peripheral
B High Peripheral
C Low Peripheral
D High Peripheral due to gold contacts.
E High Peripheral
F Low Peripheral
Tough evaluations.
PostPosted: Fri May 29, 2026 2:03 pm
Low peripheral is my initial reaction to all.
B/D/E are probably higher value, possibly enough to bump to high.
PostPosted: Sun May 31, 2026 10:07 am
I believe, and I could be wrong, when boards are this small we are allowed to put them in connector ends if there is a connector on the board itself. Case in point is board D. I would toss in connector ends.
Connector ends and low peripheral are only a .10 difference right now. You could be probably do either or and be OK.
My guesses:
A - Low Peripheral
B - High Peripheral
C - Low Peripheral or mid grade. I would probably remove the chip and toss in Mid. Are those gold pins on the ends of this board? If so Chris might allow Low Peripheral for it.
D - Connector end or high peripheral. Debatable. I would probably toss in Connector Ends but that is my opinion.
E - High Peripheral.
F - Low Peripheral.
PostPosted: Sun May 31, 2026 11:30 am
I don't understand why we've recently been getting a lot of boards with possible gold bearing ports described as connector ends.
There was this explanation by Lost at the end about connector ends that contain a small board, but D is a board that contains two USB ports that could be a connector end if they were on a cable and not mounted. Plus we can't see if these ports have gold plated pins or not.
Did I miss something?
