It is currently Mon Sep 21, 2026 10:40 am
PostPosted: Tue Jun 11, 2024 1:20 am
I've read a few topics that had replies with instructions by red circle around objects to be removed in order to keep the high grade. Hoping you could help me out in the same manner. 1st time for everything. Also could you id each board. Thank you. I've checked around and you guys easily pay the most
PostPosted: Mon Jun 01, 2026 9:03 am
Blurry photos make close inspection difficult. A good example is your photo ...291.jpg. Can not tell if glass fuses are in the upper right corner.
Sorry. I don't know how to do circles or arrows. But. I will comment.
...478.jpg Remove bracket. Low Telecom.
...252.jpg Remove 2 transformers. Remove relays. Clean Gold Finger Card.
...834.jpg Remove bracket. Low Telecom.
...815.jpg Remove bracket. High Telecom
...291.jpg Remove bracket. Are those glass fuses upper right of board? If so remove those. Low Telecom.
PostPosted: Tue Jun 02, 2026 2:45 pm
Blurry pictures make my eyes hurt! I have a hard enough time seeing as it is! I think there are two boards with fuses on them.
