It is currently Fri Nov 06, 2026 9:36 am
 Post subject: Gold Ball Bearings?
PostPosted: Wed Jun 03, 2026 10:04 am
Got a really old Toshiba copier control panel board in that had a large steel plate over the buttons and when I ripped that plate off the buttons broke apart with these ball bearings falling out. I placed them back on the board for the photos and wondering if these are gold plated or just brass, seems shiner than brass and non magnetic.
I can try to get closer photos separate from the board if needed, if gold plated would they go in gold pins?
 Post subject: Re: Gold Ball Bearings?
PostPosted: Thu Jun 04, 2026 8:36 am
Gold bearing bearings (couldn't resist) are a thing. Lostinlodos would have a better handle on this than me. But it may come down to having to test it.
 Post subject: Re: Gold Bearings?
PostPosted: Sat Jun 06, 2026 3:30 pm
Thanks Marked141, I do have these saved in a bag so I'll save them for now for sending them sometime.
PostPosted: Sat Jun 06, 2026 11:00 pm
I found some small gold balls in a red rectangle with a row of switches on one of the boards I have.
PostPosted: Sun Jun 07, 2026 2:19 pm
That is the type of switch you should check for gold bearings, they've been pointed out before by others.
PostPosted: Mon Jun 08, 2026 4:32 pm
Are they gold ball bearings or gold bearing balls? Sorry, I crack myself up :)
PostPosted: Mon Jun 08, 2026 4:43 pm
Yes, those are gold bearing. I would assume very similar to the switches mentioned.
Red, Blue, Yellow, and White are the common colors with those little rectangle switches that contain the gold bearing balls.
I aim for the Red n Blues or sometimes steel wrapped in old stuff.
PostPosted: Wed Jun 10, 2026 6:40 am
There are several posts on the red switches with gold balls. These are saleable as karat gold . Back in my early days in e-scrapping, I collected them, then discovered a magnet would attract them, ie, gold plated over iron, so I tossed them because everyone knows gold is non-magnetic. The blue variety of the switches have blades with a small gold flashing on the end, rather than balls
