It is currently Mon Jul 27, 2026 8:22 am
 Post subject: Washing Machine Boards
PostPosted: Sun Jun 07, 2026 1:37 pm
How do you guys process these? I am assuming if I remove the heat sinks, this board could go as high peripheral. However, I assume the think rubberized coating causes that last statement to be inaccurate. What do you guys do with these?
PostPosted: Sun Jun 07, 2026 5:23 pm
That's some thick sealant O.O
I think it's gotta go auto board, no box
PostPosted: Mon Jun 08, 2026 7:42 pm
I feel like there is a way to get this coating off to be able to get high peripheral price....
PostPosted: Tue Jun 09, 2026 6:41 am
That likely won’t make high peripheral. Not from my experience.
Depending on what’s under the sink, you may make midgrade or low peripheral without the sealer
PostPosted: Tue Jun 09, 2026 7:32 am
On those boards we would depopulate the mosfets, heat sinks, & capacitors. Then they would go in my mid/low box. I would not send them to boardsort via mail as I am in NJ.
Those mid/low boards would be going when I make a trip if I don't find a buyer for mid/low locally.
PostPosted: Thu Jun 11, 2026 7:01 am
Thank you all for the responses. I have been successful in the past getting the heat sinks, mosfits, capacitors and even the IC chips off of these. The coating is fairly easy to get through, I was just curious if anyone had a trick to get the entire coating off in hopes of it increasing the grading of the board. Nonetheless, I think we are all on the same page, get what I can and throw it in the low grade pile.
Yup, I have not sent in anything to Boardsort. We have family that live in Ohio so on our next trip, we plan on swinging by to drop off our cache.
Appreciate the response. I think we are all on the same page, depopulate what I can and call it a day.
PostPosted: Thu Jun 11, 2026 6:49 pm
The sun breaks down the sealant and rubber coatings quite well. Leave them in an area where only the sun can reach them for 12 hours a day. For however many days you want to leave them, it gets easier and easier. Remove the materials with a puddy knife or a smooth flat head. Be careful not to remove the small components when doing so too.
PostPosted: Thu Jun 11, 2026 6:51 pm
I pick only boards that would be High per and above. Anything lower I still throw in Low/Mid or Auto box if it's too heavy in coatings/oils
