It is currently Sat Oct 31, 2026 3:59 am
PostPosted: Wed Dec 16, 2015 3:52 pm
Is it possible/worth it to get the drive board off of lap top DVD/CD drives?? As they are already so compact and small would taking time to get the drives be worth it??
PostPosted: Wed Dec 16, 2015 5:02 pm
Only if you intended to break thr entire unit down taking the board off... you get a few pennies for it. The rest of the drive is worth more in the case of subcompact drives from scrap value.
PostPosted: Thu Dec 17, 2015 10:14 am
I gave up separating the boards a while ago... unless it is an aluminum body, it wasn't worth the hassle to break down drives for an extra few nickles/dimes. I felt my time was better spent trying to find more computers to scrap.
PostPosted: Thu Jan 07, 2016 3:32 pm
So does Boardsort pay for the subcompact drives??
I also happen to have a 3.5floppy off of an ancient Laptop which is also a subcompact drive compared to the standard 3.5floppy drive.
Would boardsort pay for them more than a standard 3.5in floppy drive??
PostPosted: Thu Jan 07, 2016 4:43 pm
Boardshort purchases most drives including desktop and laptop, under the cd/dvd/floppy drive class in miscellaneous.
Your best payout would be to remove the case and board. pop the dlp from the laser assembly. There's a guide in what's inside it part 2.
Sell the board And dlp to boardaort.
The case/frame with motors and stufd attached; if steel will go cbm #3 (10-14c/lb) if aluminium you'll get old/breakage al at 19-27c/lb. If magnesium you'll fetch clean steel motor rate at 25c-40c/lb
