It is currently Fri Nov 06, 2026 1:42 am
 Post subject: More little boards
PostPosted: Sat Jun 13, 2026 4:17 pm
For #1, I gave up on trying to remove the plastic piece with the numbers, it is attached very strongly to the board haha.
#5 I snapped in two by accident while removing it, still hanging on by a thread.
 Post subject: Re: More little boards
PostPosted: Tue Jun 16, 2026 2:09 pm
I am still learning so please wait for others to chime in.
1. use a chisel and a hammer. Should come off. As is I'd say mid-grade. If you remove the larger components then I would say it would slide into peripheral grade. Possibly high.
2. Low Peripheral
3. Are those connector ends gold? If so Connector Ends. If not I would say Mid-grade.
4. Leaning toward high peripheral.
5. Low Peripheral.
PostPosted: Tue Jun 16, 2026 4:36 pm
1 is at least low peripheral as is. I'm not sure if that specific style display needs to come off or not. It could be fine and may push into high peripheral anyway.
2 agree
3 midgrade
4 low peripheral
5 if it's low peripheral the button IC is doing a lot of heavy lifting. I would lean midgrade.
