It is currently Wed Sep 16, 2026 4:56 am
PostPosted: Sun Jun 14, 2026 8:36 am
So I have these three boards, the three have screens on one side. Just curious how the screens impact grading, if there is a way to remove them to make the board worth more, or do I just leave them be and move on. Feedback is always appreciated.
PostPosted: Sun Jun 14, 2026 3:29 pm
These LCD type screens must be removed.
Other types of displays will vary in needing to come off or not but even ones that can stay must be protected if glass, usually a piece of tape is enough to keep the glass from breaking and causing mayhem in those cases
PostPosted: Sun Jun 14, 2026 5:41 pm
Once removed, what are they considered for grading?
PostPosted: Mon Jun 15, 2026 2:34 pm
High peripheral seems likely for these.
The first board needs the battery removed. If the wire terminals are magnetic I would pull them off too just to be safe.
The last board is a bit bigger and seems less populated with good stuff so may be low peripheral
PostPosted: Sun Jun 21, 2026 9:43 pm
OP I used a chisel and a hammer to remove screens. There are other ways but that way is my favorite and seems to keep the screens in tact (for the most part).
PostPosted: Mon Jun 22, 2026 8:01 am
Fortunately none of these should require a chisel. One will essentially peel off and the other two have metal pins on one side that you can break by moving the screen back and forth. If the pins were on both sides a chisel might be necessary.
