It is currently Fri Sep 11, 2026 4:26 pm
PostPosted: Tue Jun 16, 2026 5:15 pm
so basically what the title infers. What category do pentium 2 rype laptop cpu's go under?
PostPosted: Wed Jun 17, 2026 8:32 pm
Aren't there at least 3 form factors on the Pentium II? We probably need a picture.
PostPosted: Thu Jun 18, 2026 9:18 pm
I'm no good with knowing chips by name, so I Google. I saw a pentium ii in apple cpu form and green/brown fiber no metal form.
So...if both exist, we need a picture or specific chip info from the OP.
PostPosted: Fri Jun 19, 2026 11:42 am
I’m assuming it’s either a ceramic pga with no gold cap or a black fibre pga.
They go as is. I have a long post coming tomorrow explaining the story beyond that.
PostPosted: Fri Jun 19, 2026 12:33 pm
Quote:
mobile Pii's that are not a BGA or soldered to the board almost always use a module/card like a apple CPU.
This is exactly why this site service exists.
I got hung up on the slot idea posted…
I’ve seen only 1 slot cpu in a laptop in my life: and only know of 3 that existed.
As for card based vs die based, it’s likely I was then and remain deeper into development when it comes to fixing and working with equipment, but most of what I’ve seen are pga. But according to the interwebs I’m wrong and BGA was most common.
marked141 Pointed out 3, there’s actually 6
ceramic double die (size of a P-pro) pga
Ceramic double die BGA
Fibre double die pga
Card type pga
Card type bga
Slot
And real world (again have a write up coming in 12 to 24 hours) some stupid idiots decided to stick slot processors into laptops: both Intel and AMD. And they burnt out permanently the moment you tried to do anything that would require a pentium anything or k6 over a 486.
As Randy orton has said, multiple times
Quote:
Stupid stupid stupid stupid
PostPosted: Fri Jun 19, 2026 1:25 pm
My research went as far to identify if there were any differences that affect scrap grade. I found three pretty quick and stopped. Hopefully the OP sees the conversation so they can confirm what they have and sort accordingly ¯\_(ツ)_/¯
PostPosted: Sat Jun 20, 2026 2:13 am
austin86 wrote:
indeed, we can debate all day long but we will never know what OP has until he posts a photo of it.
Exactl
PostPosted: Mon Jun 22, 2026 5:31 am
Go here for my blah on slot processors
viewtopic.php?f=3&t=25336
