PostPosted: Fri Dec 18, 2015 9:06 pm
I have two types of boards and need to know the value Thanks One of them looks like Back Plane Expansion Board?
PostPosted: Fri Dec 18, 2015 10:45 pm
The top photo will most likely go peripheral. You're gold pin connectors are there and ics... I'm guessing but since floppy drive boards make the cut this probably will too.
Bottom picture is definitely peripheral
PostPosted: Sun Dec 20, 2015 5:25 am
Thanks. Also what are you guys paying for shredded hard drive with boards?
PostPosted: Sun Dec 20, 2015 5:40 am
No idea. I'm not an employee. But shredded hard drive with board is probably in the same range as most high grade shred.
I doubt boardaoart is interested at all. My guess is a major yard would give you copper #2 rate which as of Friday had a national average at $1.50. or #3 @1.06
If they do I'd expect it to be somewhere between there on the lower end.
A shredded whole hdd adds considerable disadvantage to the original. There aren't to many places world wide that deal with such "true" shred in recycling since separation is a major issue.
PostPosted: Sun Dec 20, 2015 5:41 am
And don't balk at an offer of 10 or 15 cents. It just means they don't know what to do with it and/or have no outlet.
PostPosted: Sun Dec 20, 2015 8:59 am
At one of the buyers I know awhile back they were paying $0.30 lb for them
PostPosted: Mon Dec 21, 2015 11:26 am
I remember on the quote page there was a category for bent or punched hard drives. Don't remember if that category was for drives with the board, or if there were two categories for bent or punched drives, one being with the boards and the other without.
PostPosted: Mon Dec 21, 2015 11:39 am
Whole punched drive without board.
I believe that was the category.
PostPosted: Mon Dec 21, 2015 6:10 pm
You may want to email Chris directly about shredded materials, they may not accept them.
PostPosted: Wed Dec 23, 2015 9:30 pm
Thanks lostinlodos..I emailed Chris but im guessing i wont get a reply till next year.
I also have these two boards if you can help me what they would categorize this as?
