It is currently Sun Jul 26, 2026 1:06 pm
 Post subject: What do I have
PostPosted: Fri Jul 03, 2026 4:25 pm
Are these low telco? Gold finger card? Midgrade and cut the fingers off?
 Post subject: Re: What do I have
PostPosted: Fri Jul 03, 2026 6:07 pm
With all those empty sockets id assume low grade and just trim the fingers off but wait for someone with more knowledge to post
PostPosted: Fri Jul 03, 2026 6:18 pm
Yeah that’s what’s throwing me I’ve never had anything with so many empty IC spots so I’m not positive
PostPosted: Fri Jul 03, 2026 7:26 pm
These are my reference points for older style boards:
viewtopic.php?f=4&t=20854&p=40413&hilit=older#p40413
viewtopic.php?f=4&t=20899&p=40643&hilit=older#p40643
viewtopic.php?f=4&t=20985&p=40963&hilit=older#p40963
Are the gold fingers one sided or on the back also?
41 Has an advantage of being smaller for what should be decent gold fingers, plus possible gold in the switch; high peripheral at minimum
43 Has a lot more board to fingers. Low peripheral seems possible to me
44 A bit different than the others and my references but has ICs and gold fingers still, easily high peripheral, possibly better.
PostPosted: Sat Jul 04, 2026 11:55 am
All have double sided gold fingers
PostPosted: Sat Jul 04, 2026 12:45 pm
In that case I'm sure you shouldn't get lower than what I think with possibility for a step up.
PostPosted: Sat Jul 04, 2026 12:54 pm
So shouldn’t trim the fingers off, correct?
PostPosted: Sat Jul 04, 2026 6:41 pm
The gold fingers are definitely going to be a big part of the boards making the grades I think they can go in.
I personally wouldn't trim them.
