It is currently Sat Aug 22, 2026 8:57 pm
PostPosted: Sat Aug 15, 2026 4:55 pm
Hey all, I just finished scrapping a batch of 40+ laptops, and I've got a few bits that I'm not sure what to do with. The first is the sheet of film with all the little contact points that comes out of a laptop keyboard. Does it count as wire? Anything higher value in there? I'm attaching a picture of the bit I mean.
I'm also wondering about the actual LCD screen out of a laptop display. The glass plates with the liquid sandwiched between them that like to break no matter how gentle you try to be when freeing them from the adhesive. I don't have a picture of those but hopefully someone knows what I mean. A) Is there anything in there that would make it worth taking to my local yard? and B) Is there anything in there that would make it worth taking to the county haz-mat dropoff?
PostPosted: Sun Aug 16, 2026 8:17 am
The ribbon cable would be wire, although I think they have a separate category for ribbon cable that might be a little more.
The films themselves I think have trace amounts of silver contacts? but I'm not positive and no they are not wire. More than likely they're just junk unless you have serious weight.
Virtually no one takes LCD screens. Boardsort does not, and many yards won't either. If I leave all the steel/plastic casing around them my yard takes them as shred.
PostPosted: Mon Aug 17, 2026 10:27 am
I’ve seen post where the silver mylar is put as mixed wire
