It is currently Sat Aug 22, 2026 11:58 am
PostPosted: Sun Aug 16, 2026 8:17 pm
Can I toss these into the connector ends?
PostPosted: Mon Aug 17, 2026 7:03 am
I really doubt it but best would be to call or email Chris.
PostPosted: Mon Aug 17, 2026 8:18 am
No.
Large boards are low grade (could be the picture but I see no gold on those)
Smaller boards...they're just blurry enough I can't tell, is there nothing mounted on them except the connector? They'll essentially be blanks if that's the case and getting a direct answer from Chris is best. If I had to guess low peripheral seems likely.
PostPosted: Mon Aug 17, 2026 9:16 am
Bad pics. There's really a lot of gold enig. The small ones actually have some gold connector pins right in the middle.
PostPosted: Mon Aug 17, 2026 1:48 pm
Large boards would be midgrade if that's the case.
Small boards, same answer as above
PostPosted: Tue Aug 18, 2026 3:33 pm
Chris said Low Grade Peripheral. Currently $3/lb
PostPosted: Wed Aug 19, 2026 11:38 am
Probably a very thin layer of gold plating. Nothing like they used on boards from the 70s!
